Map will not turn on when coordinate system is CRS:84
ognjenJM4YZ
ognjenJM4YZ
Greetings,
I have an issue with map not turning on in a drawing that has CRS:84 coordinate system assigned to it.
After I execute command GEOMAP or click button in the toolbar, only thing that I get is message in the console that says: "No geographic location assigned". Has anyone encountered this problem before and, does anyone know a possible solution?
Thank You in advance 🙂
Pointdump
Hi Ognjen,
Live Maps don't work with Geographic Coordinate Systems. You'll need to use a Projected Coordinate System, like WGS84.PseudoMercator (EPSG 3857).
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ognjenJM4YZ
Thank You for the help.
