Using Map 5 I have a problem with Map Export. Error reads as follows:
Module AcMapImpExpUI.arx cannot load module AcMapImpExp.arx. The module may be missing, or another component upon which it depends may not be configured correctly.
I have looked in the Program folder and can see three files, the two listed above and a DLL file named AcMapImpExpUIResource. This is a new error as I have used this routine numerous times without problem. Is there another file referenced that may have been corrupted?
Thanks for any answers
Neil
