Map 3D Toolset is missing in AutoCAD 2023
vermouthGJYZR
vermouthGJYZR
Community Visitor
Community Visitor
Hello, when I was trying to import a shp file into my autocad 2023, I can neither find Map Import under Insert tab -
Import panel nor use the mapimport command. When I checked cui there's no such file as map.cui at all. So I went to uninstall and reinstall AutoCAD again but the map 3d toolset is still not loading at all. Can anyone help me to troubleshoot what went wrong? Thanks!
cadffm
AutoCAD 2023 is AutoCAD 2023
MAP3D 2023 is MAP3D 2023
two separate programs!
Download and install MAP3D and use MAP3D..
https://manage.autodesk.com/products
Sebastian
braudpat
Hello @vermouthGJYZR
+1 with @cadffm
So please install ACAD MAP 202X !
The Health, Regards, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
nasos_kats
Observer
Observer
I had the same problem. I found it inside Autodesk Desktop App.
