Map 3D Mapbooks -- change of UCS
mmendezJLGA9
mmendezJLGA9
I have an area that is in state plane. I can use the Mapbooks and it will work with my template, but I want to rotate the view so the viewport is square with my area. I changed my UCS in the template, then in the drawing, then in the template and the drawing, but the viewports end up somewhere else.
Am I doing this wrong or should I start a new template by dissecting the one that is out-of-the-box (which I have not tried rotating)?
Pointdump
Hi Marcos,
Have you tried DVIEW >> TWIST?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
