LISP seletion set by text style name
I am trying to write a lisp in which my selection set is ALL text entities of a specific text style in the dwg; however; I have apparently been unsuccessful in creating the selection set.  I am not receiving a syntax error but rather my selection set never gets created.
Please see below my latest attempt and advise me of where I have gone wrong:
(setq st (ssget "_X" '((0 . "TEXT,MTEXT") (1 . "<MY TEXT STYLE NAME>"))))
Thanks for your support!
I have discovered that my Group Code number was wrong, so I have changed the "1" to "7" and now the selection set is made.
HOWEVER, how may I add to the conditions of this selection set so that the result excludes any of the designated text style that reside on a certain layer, yet retrieves those that reside on all the other layers?
Pointdump
B,
Have you tried QSELECT?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Thanks for the help Dave, but I needed to construct this inside a lisp routine, and to this end I believe I have finally stumbled upon the solution.
What I needed the lisp to do was select all the text and mtext of a certain style and the following accomplished this:
(setq st (ssget "_X" '((0 . "TEXT,MTEXT") (7 . "MY TEXT STYLE NAME"))))
However, I also needed to exclude from this selectoin all the text and mtext that resided on one specific layer and now the following accomplishes this:
(setq st (ssget "_X" '((0 . "TEXT,MTEXT") (7 . "MY TEXT STYLE NAME") (8 . "~MY SPECIFIC LAYER NAME"))))
Note the tilde "~" preceeding MY SPECIFIC LAYER NAME .
This I have learned, tells the program to exclude any of that Group Code (in this case 8 = layer name) from the selection set.
I'm not very proficient with lisp but I'm learning.
Thanks again,
Barry Navarre
Lafayette, Louisiana
