- Mute
- Permalink
- Report
I'm working in both ArcGIS Pro and Map3D. I regularly receive tree survey data in the form of Civil3D COGO points. These COGO points typically have been stylized different than I need them to be, so I'm trying to assign a block I've created to them with a scale based off of each tree point's diameter.
So far, I've realized there are limitations in Map3D in dealing with COGO points. I can't revise labeling or which block is used. It just seems to have limited functionality. I'm sure there are many more options in Civil3D, but I don't have a license for it. Is there an SOP to making this work?
I've tried opening the survey file in GIS and converting to shapefile, then performing a mapimport and assigning a block. The blocks come in fine, with correct placement, attribute-based layering, and attached attributed data...but I'm not sure how to get the tree block to scale appropriately upon performing the mapimport. Is there a way to do this?
Any other methods to achieving this are welcome. I have to perform this task pretty often and usually just use a not-so-pretty workaround, so I'd like to have a more efficient process. Thanks for any help on this.
