Is there a variable whose value determines the coordinate system
АлексЮстасу
Advisor Advisor
АлексЮстасу
Is there a variable whose value determines the coordinate system? For example, the coordinate system code?
I'd like to assign a coordinate system in a macro. Or programmatically, reading a variable and its value from a text file.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
braudpat
Hello ARX Master
I don't think there is a specific variable !? Please check ?
I am tired and I have about 30-32 degres at home !
But you can assign the current projection system to an ACAD Field ...
With the magic expression : %《\AcVar cgeocs》%
Happy WE, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
АлексЮстасу
Hi, Map Master!
And we now have only +11 degrees in the afternoon! Although a week ago it was up to +30.
Obviously, to balance with you.
Alas, I am never a programmer at all.
I don’t even understand in which field to write this %《\AcVar cgeocs》%.
braudpat
Hello
I am speaking about dynamic fields !
INSERT / FIELD... Select the System variable CGEOCS
Regards, Patrice
Patrice BRAUD
АлексЮстасу
Euronews tells me that in southern France the temperature is more than 40, and there have even been fires.
Hold on!
I could not understand, because I never used this INSERT / FIELD, I did not know about it. Thank!
But this way only I can learn about CS?
I would like to set CS by defining a variable.
braudpat
Hello
OK OK now I understand really what you need !
There is not a direct system variable but with a single line Lisp Code , you will do the job !!
(ade_projsetwscode "xxxxxxxx")  for ACAD MAP or for ACAD CIVIL
---- To erase the projection system ---
Commande: (ade_projsetwscode "")
T
---- Projection System = "LL84" ----
Commande: (ade_projsetwscode "LL84")
T
---- Projection System = "Lambert93" ----
Commande: (ade_projsetwscode "Lambert93")
T
Regards, Patrice (The Old French EE Froggy)
Patrice BRAUD
АлексЮстасу
Ok!
I understood this:
1. Install CS using the definition of a variable is impossible.
2. In the macro or from the command line, I can specify CS using the expression: (ade_projsetwscode "<CD code>").
Thank you!
