That seems to be a dot net framework error, I received it many times in
testing and was never able to get around it completely. I was hoping it was
fixed in the final release or would provide the installer more info. Only
thing I know for you to check is the version of dot net framework, and if
you have any newer "beta" versions of software from any other product
installed. I had trouble getting it to work with Microsoft Visual Basic
Express installed.
Murph
wrote in message news:4818678@discussion.autodesk.com...
I'm getting errors when installing the upgrade.
The first one is:
Internal Error 2908.
{2F50FBD-4FB3-40660A527-C4039E6A0997}
That appears just before it starts installing files. I click OK and
everything continues as it should until just after the registry entries when
I get this error:
Eroor 1935. An error occured during the installation of assembly ;stdol,
Version=.0.3300.0",PublicKeyToken=03F5F7F11D50A3A",GUID=0020430-0000-0000-c000-000000000046",LCID=033'".
Please refer to
Help and Support for more information. HRESULT: 0x80131047
I have the option to click OK on that. I do that and the installation rolls
back completely and leave me with a log file, which I've attached. Help and
Support proved as useful as the message above.
If anyone could point me in the right direction to find a solution that
would be great.
Thanks in advance,
Chris
