importing LAS files to autocad map 3d 2016
Hello everyone, I am trying to figure out how to import las files into the 2016 software. I know that in the 2015 version all I had to do was click the "data" button under the Task pane and select "add point cloud" then "creat new index", but in the 2016 software it doesnt have that option. I can bring them in as a raster by using recap, but I would rather just use the data I have and index them to an .ISD file then create my 3d surface data from that. Please Help.
Replies (17)
I meant RCS file not raster
Pointdump
Evan (Evan Almighty, like the movie?),
I haven't done anything with LAS files, but I think you need to use ReCap to work with Point Clouds. (I might be wrong.)
undefined
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Oh goodness, I hope that's not the case. That would be a huge step back for me. I would pretty much have to relearn my lidar map making. I use it to locate sinkholes/caves but haven't been able to use it in almost 2 weeks. I use the 1 ft contours to determine the elevations of the sinkholes. it helps me guess at how deep a cave entrance may be.
I solved it myself. All I had to do was manually type in the command MAPPOINTCLOUDMANAGER and it brought up the point cloud manager I needed to import .LAS files. I dont understand why they didn't leave it setup like the 2015 software.
Pointdump
Evan Almighty! Good to hear you found it.
When I type in MAPPOINTCLOUDMANAGER I get this:
undefined
But the Help Section says the Map Point Cloud Manager is here:
undefined
Which comes up with a completely different Dialogue Box that allows you to Import RCP(Project) and RCS(Scan) files. I don't know what the difference is.
Dave
Dave Stoll
Las Vegas, Nevada
Yes you are correct. The point cloud manager window that comes up when you type MAPPOINTCLOUDMANAGER in the command window is for indexing LAS files and processing them to .ISD files. They then can be added to the map and will have a layer under the task pane. In 2015 all you had to do was click "data" in the task pane, and click "add point cloud data" then "create new index". The help section for 2016 needs work, and I think they need to fix that feature so it works like it did on 2015
By the way... If you haven't dabbled with LIDAR LAS files, you should really consider checking out what it can do. Its pretty amazing.
Pointdump
Evan,
Thank you. One of these old days I'm hoping to get a chance to work with Point Clouds.
Sounds like Autodesk changed 2016 for the worse. You should head directly to the Map 3D IdeaStation and let AutoDesk hear about it:
http://forums.autodesk.com/t5/autocad-map-3d-ideastation/idb-p/90/tab/most-recent
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Evan,
With the freely available data out there, I should investigate LIDAR. Tomorrow's project! Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
TerryDotson
One of the best considerations is that they have the bounding box in the header section.  That means (given an area of interest) you can evaluate thousands of huge LAS files in seconds and discard those outside the AOI without reading the actual data.
Is this method still possible? "MAPPOINTCLOUDMANAGER" is an unknown command in AutoCAD Map 3d 2018. This is the entire reason I got this software.
Thank you,
Chris
Alfred.NESWADBA
Look to my screenshot, for me it's working (Map 3D 2018 English)
When you start the command with a leading dash (-MAPPOINTCLOUDMANAGER), does it also react with "unknown command"?
BTW: which lanuage of Map3D are you using?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Thanks for looking into this Alfred. I'm using the English version.
When I type "-MAPPOINTCLOUDMANGER" or "MAPPOINTCLOUDMANAGER" it returns 'unknown command'.
When I type "POINTCLOUDMANAGER" I get the "POINT CLOUD MANAGER" window as shown in your shared screenshot. Is this the same as the "MAPPOINTCLOUDMANAGER"? I was under the impression that it is not. Within this window, it shows nothing for me because I have not added any point cloud datasets (that's what I'm trying to do!).
I also noticed that your screenshot's included example point cloud data is titled "ReCap". We need to be able to analyze the data without going through ReCap, which I believed could be accomplished with "MAPPOINTCLOUDMANAGER". Are they effectively requiring any point cloud data be processed (very slowly and likely unsuccessfully in our case) through ReCap?
Chris
Alfred.NESWADBA
You are correct, I'm wrong. I only copied your command to the command-line and AutoCAD used it's AutoCorrect-feature and replaced the command from MAPPOINTCLOUDMANAGER to POINTCLOUDMANAGER and started the AutoCAD dialog, not the one you are looking for.
I guess that will not be possible any more wihout ReCap (except you do have Civil 3D).
Sorry for the confusion! - alfred -
Alfred NESWADBA
guido77
Hello.
On Autocad Map 3d 2018 I don't have MAPPOINTCLOUDMANAGER either.
I have POINTCLOUDMANAGER which brings an empty window with no tools or options to import anything.
Any ideas?
Thank you.
Alfred.NESWADBA
>> Any ideas?
You need Autodesk ReCap to convert the LAS to RCS/RCP, then you can use it in Map3D.
- alfred -
Alfred NESWADBA
guido77
Thank you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
