How will get Attach/Detach Object data table in autocad map 3D 2019
aditi.khamkar
aditi.khamkar
Which command or how will I get Attach/Detach Object data table in autocad map 3D 2019
ChicagoLooper
Hi @aditi.khamkar
Assuming you have already created an Object Data Table you can attach the Table. Do this:
Go to Create Tab=>Drawing Object panel=>Attach/Detach Object Data
If you haven’t created an Object Data Table, go to Map Setup Tab=>Attribute Data panel=> Define Object Data
Chicagolooper
aditi.khamkar
Thank you Sir.
