How to change DEC in DMS in MAPTRACKS tool
branimir_beljo
branimir_beljo
Hi, if someone could help me with this issue I will be grateful. In Drawing Units window, under the Angle setting I choose DEG/MIN/SEC as a Type and desired precision. But when I start MAPTRACKS tool, in the window the coordinates shown are not expressed in DEG/MIN/SEC but in DEC values. Can I change this in order to have them shown in D/M/S form in MAPTRACKS? The version od CAD is 2018 MapACAD.JPG
ChicagoLooper
If you want DMS in MAPTRACKS don’t use the UNITS function. Use the OPTIONS button in the MAPTRACKS palette.
First, access MapTrack Options by clicking the Options button circled in blue.
Then, under the General section, check the box labeled ‘Format lat/longs as DMS.’
Chicagolooper
branimir_beljo
@ChicagoLooper  Great, problem is solved with your help. Many thanks.
