HELP TO CREATE A SURFACE OR MESH FROM CONTOURS THAT HAVE ELEVATION ATTRIBUTES.
Hey guys,
I need some help to be able to create a surface or a mesh from contours.
The contours that I have have elevation so if I 3DORBIT  I can see the terrain but i want to be able to add a surface or mesh over it.
Any ideas?
Thanks!
WarrenGeissler
You can create a GeoTIFF from that data (with a lot of hoops to jump through. You need Civil 3D to create a true triangulated surface from contour data like this. If you are a student then you have access to Civil 3D, if not then you can download and use the 30 day trial copy. WHATEVER you do - do NOT attempt to use the AutoCAD LOFT command on these - you will kill your system. (Been there - done that)
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Thanks! I will try it
Nick
Pointdump
Nicholas,
Can you elaborate on "...add a surface or mesh over it"? Map 3D has lots of display options for a surface, but what do you need to do exactly?
Can you post your drawing and/or contours?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
