Egor,
It hints at possibilities. I just wish I was smart enough to understand all this:
Define a custom Coordinate Operation
Custom Coordinate Operations are defined in epsg_operations.properties file. This file has to be placed into the user_projections directory, inside your data directory (create it if it doesn’t exist).
Each line in epsg_operations.properties will describe a coordinate operation consisting of a source CRS, a target CRS, and a math transform with its parameter values. Use the following syntax:
<source crs code>,<target crs code>=<WKT math transform>
Math transform is described in Well-Known Text syntax. Parameter names and value ranges are described in the EPSG Geodetic Parameter Registry.
Examples
Custom NTv2 file:
4230,4258=PARAM_MT["NTv2", \
PARAMETER["Latitude and longitude difference file", "100800401.gsb"]]
Geocentric transformation, preceded by an ellipsoid to geocentric conversion, and back geocentric to ellipsoid. The results is a concatenation of three math transforms:
4230,4258=CONCAT_MT[ \
PARAM_MT["Ellipsoid_To_Geocentric", \
PARAMETER["dim", 2], \
PARAMETER["semi_major", 6378388.0], \
PARAMETER["semi_minor", 6356911.9461279465]], \
PARAM_MT["Position Vector transformation (geog2D domain)", \
PARAMETER["dx", -116.641], \
PARAMETER["dy", -56.931], \
PARAMETER["dz", -110.559], \
PARAMETER["ex", 0.8925078166311858], \
PARAMETER["ey", 0.9207660950870382], \
PARAMETER["ez", -0.9166407989620964], \
PARAMETER["ppm", -3.5200000000346066]], \
PARAM_MT["Geocentric_To_Ellipsoid", \
PARAMETER["semi_major", 6378137.0], \
PARAMETER["semi_minor", 6356752.314140356]]]
You can make use of existing grid shift files such as this explicit transformation from NAD27 to WGS84 made up of a NADCON transform from NAD27 to NAD83 followed by a Molodenski transform converting from the GRS80 Ellipsoid (used by NAD83) to the WGS84 Ellipsoid:
4267,4326=CONCAT_MT[ \
PARAM_MT["NADCON", \
PARAMETER["Latitude difference file", "conus.las"], \
PARAMETER["Longitude difference file", "conus.los"]], \
PARAM_MT["Molodenski", \
PARAMETER["dx", 0.0], \
PARAMETER["dy", 0.0], \
PARAMETER["dz", 0.0], \
PARAMETER["src_semi_major", 6378137.0], \
PARAMETER["src_semi_minor", 6356752.314140356], \
PARAMETER["tgt_semi_major", 6378137.0], \
PARAMETER["tgt_semi_minor", 6356752.314245179]]]
Affine 2D transform operating directly in projected coordinates:
23031,25831=PARAM_MT["Affine", \
PARAMETER["num_row", 3], \
PARAMETER["num_col", 3], \
PARAMETER["elt_0_0", 1.0000015503712145], \
PARAMETER["elt_0_1", 0.00000758753979846734], \
PARAMETER["elt_0_2", -129.549], \
PARAMETER["elt_1_0", -0.00000758753979846734], \
PARAMETER["elt_1_1", 1.0000015503712145], \
PARAMETER["elt_1_2", -208.185]]
Each operation can be described in a single line, or can be split in several lines for readability, adding a backslash “" at the end of each line, as in the former examples.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
