I am using Map 3D 2005. In order to place a grid on a map in the past, I have used a horizontal Xline at a particular multiple of 1000 and copy rotated it for the vertical. I then trim them to the correct length and array them as many times as needed on the correct spacing. I then use a lisp routine for labeling them. Is there an easier, faster way of doing this in Map or is that something for the Wish List? I tried using the grid surface feature, but was unable to discover how to make it display or how to label it.
Thanks for any advice,
Ray
