AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
GEO Command map missing
1 REPLY 1
381 Views, 1 Reply
I've been searching for this question, and I can't seem to find any answers, so my apologies if it's been asked before.
When using the 'GEO (GEOGRAPHICLOCATION)', the map works fine. You save your work, then you close it. The problem is when you reopen your file, the map is not there anymore. Is there any way to fix this issue? Is there a setting I'm not aware of?
The reason I'm insistent in using this command is because you only have to type in the address.
Thanks.
1 REPLY 1
Pointdump
Jessica,
Geographic Location is meant for use in Vanilla AutoCAD. To use it in C3D or Map, please see <<<This Video>>>.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
