I've been searching for this question, and I can't seem to find any answers, so my apologies if it's been asked before.
When using the 'GEO (GEOGRAPHICLOCATION)', the map works fine. You save your work, then you close it. The problem is when you reopen your file, the map is not there anymore. Is there any way to fix this issue? Is there a setting I'm not aware of?
The reason I'm insistent in using this command is because you only have to type in the address.
Thanks.
