AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
generate new pattern/hatch
2 REPLIES 2
429 Views, 2 Replies
Hi Community!
I got stucked with my pattern/hatch-issue and hope I can find some new proposals here.
I would like to generate a new pattern/hatch out of a font. I know there are *.pat-files, but this pattern is quite complicated. I already reduced this symbol to normal lines which are now saved in a dxf (see attached file).
Is there a possibility to define this as a pattern? The best would be to save it as a *.pat-file.
I'm working with AutoCAD Map3D 2014 SP2
Thanks in advance!
Maria
Tags (2)
2 REPLIES 2
olivier.eckmann
Perhaps you can try this
If I remember it's developped in vba.
Olivier
in reply to: olivier.eckmann
Hi Olivier
thanks for your reply. That's exactly what I was looking for.
Unfortunatly it didn't help. The versions are not compatible. 😞
I'll go on searching for a tool ...
Maria
