Finding Duplicate objects, and deleting BOTH?
tamas.halasz
tamas.halasz
Hi!
We have been looking for a working solution all day for this, but we cannot find anything that works with the current version of map 3D.  The main thing we are looking for is finding duplicate lines, blocks, etc., and if it's duplicated select or even delete them both. Mapclean would only delete one of them. Any ideas? We are using Map 3D 2019.
Thanks in advance!
Br,
Tamás
Replies (9)
АлексЮстасу
1. If you need to find duplicate objects, then in MAPCLEAN you can use the Interactive mode - do not delete, but only mark with marks all duplicate objects.
2. If you want to delete duplicate objects, then enable the mode Delete original objects and create new objects and Create on new layer. Then objects from this layer or the whole layer you can be deleted.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
WarrenGeissler
"If you want to delete duplicate objects, then enable the mode Delete original objects and create new objects and Create on new layer. Then objects from this layer or the whole layer you can be deleted."
VERY smart solution! Smiley Happy
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
tamas.halasz
These functions were the first thing i tried, and the marking kinda works, but we have too much work to delete them all manually.
2 nd - Tried this as well, and it sounds like that is how it supposed to work, but sadly it moves everything thats is marked to the new layer, not just the duplicates 😞
Thank you tho.
АлексЮстасу
Oops!
I did not notice that the non duplicate is also transferred to a new layer ...
I apologize!
luis.venturaP3D8J
test
tamas.halasz
testt
parkr4st
consider  QSELECT  after a copy of the .dwg is made for backup
If there are unique enough properties it may be possible to separate objects by layer or length for examples.  Making a new layer named "junk" for example and change the property of objects to that layer so the objects can be isolated by freezing the layer or erasing all on the layer.
Gary_Braun
This isn't a uniquely "Map 3D" solution, but have you tried using the AutoCAD "OVERKILL" command? I've had pretty good success with it in the past.
Peter2_1
Your problem seem to be a "Pure AutoCAD" and not a "Map" topic. You could try to ask again in the AutoCAD and/or in the Lisp-forum.
AutoCAD Map 3D 2023 German / Oracle
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
