FDO connection to postgresql
Hi all,
I have problem with my project.
1. 4-5 working station (Windows 7- 64bit, AutoCAD Map 3d 2014)
2. postgresql database server 9.2
After map attached about 10000 -50000 map features
 a day due to quickly panning and zooming around in model space. The error window displays this: "FATAL ERROR: (see image below).
It occurs even in new drawing after period of time(5- 15) minutes.
So, is anyone having a similar problem or has anyone found a solution for this?
Thanks in advance for your input!
Pointdump
T,
Run _AUDIT. That might help pinpoint the problem.
Does the program crash with EVERY drawing or just particular ones? Have you tried opening the drawing outside of your server?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Thank you Dave.
Program crash with every drawing even new drawing if layers from postgresql database are loaded while zoom or pan
May be  depend from quantity of map features and network problems or server response?
Sincerely,
Michael
Pointdump
Michael,
Usually, a large dataset will slow down the program, but a crash indicates a problem with more than volume.
Did you try running an _AUDIT?
Dave
Dave Stoll
Las Vegas, Nevada
Hello Dave,
Yes, But  new drawing is empty, only  map features connected from database.
I got same error with different files.
All files does  not contain any error.
This crashed only when FDO connecting to postgresql database.
