are you using mapexport to .shp file type?
If so, you can only export to one of point, line, polygon or text in the process.
selecting polygon requires closure for the polygon to work correctly, so any open lines will not be included in the export.
There will be a message as to how many objects successfully were exported on the command line. How many of the 270 exported?
dave
"Do I need to convert polylines closed and open to closed polygons first? Then try to export out to Arc Map in shape/polygon format "treat as closed polygons" --> yes, only if closed they will export as polygons. You can quick-select all polylines and "close" them all in AutoCAD property window at same time.
Rob
Thank-you for the responses I was able to complete the export of all polygons to ArcMap. Kind Regards Sounds
