AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export a GEOMAP image?
4 REPLIES 4
toney.lowery
7660 Views, 4 Replies
Thanks for taking a look at this post.
I have a file that includes an aerial image I generated with the GEOMAP command. I ned tot share this file and the aerial with a contractor who does not have Autocad 2015. I tried using the eTransmit so I'd get everything in the file but the aerial did not export. Is there a way to either embed the aerail in the file or export it seperately?
Toney
4 REPLIES 4
Murph_Map
in reply to: toney.lowery
Have you tried to plot to PDF with the DWGToPDF .pc3?
Murph
Supporting the troops daily.
toney.lowery
in reply to: Murph_Map
I can plot a pdf but doesn't that lose all the georeferencing? I guess I
could draw a rectangle from corner to corner on the captured geomap image.
Then plot a pdf of the image and let the contractor use the rectangle to
align the image. But I was hoping for something a little less Rube Goldberg
like.
antoniovinci
Another old-school technique:
  1. in the Plotter Manager install the "TIFF Uncompressed" virtual printer
  2. plot to it in high resolution
  3. import the brand new TIFF file
  4. command _ALIGN to calibrate it in the actual drawing
  5. finally you can georeference the aligned TIFF by means of this jewel
I did the same.
- Plot the GEOMAP image to a high-res TIF or PNG at the same shape as the clipped GEOMAP image. I usually clip a square GEOMAP image.
- Set the virtual printer to an image size of 5000x5000 or higher if needed.
- Plot the GEOMAP image and save the new image file to the project folder.
- Reference the new image.
- Position and scale the new image over the clipped GEOMAP image to get it geo-referenced.
- Delete the clipped GEOMAP image.
I hope this helps.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
