I've tried downloading and installing an educational license for AutoCAD Map 3D onto my new laptop (Windows 10, 64-bit), but it fails every time. I've tried every version available 2014-2017 and I just keep getting the message that it has installed but with bits missing, and the bits missing are everything!?
What am I doing wrong?
Log below:
Solved by TravisNave. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
you see that you've got errors 1603 as well as 1619, have you tried to search for that errors?
There exists already a lot of valid suggestions for how to proceed ... >>>click<<<
- alfred -
Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
If you are having problems downloading your 2017 software from your Autodesk Accounts page or from the Trial version, then please see this list of downloads provided here:
http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
Good Luck!
