Your ecw has an irregular shape. It needs to be ‘clipped’ so Map3D can read it.
Unlike other programs that have the capability to understand funny shaped images (Global Mapper can handle your image) M3D cannot understand your ecw. Using Global Mapper or another capable GIS program, clip your image to a smaller sized square or rectangle. You may include some of the white parts or you may clip it and exclude white parts altogether. It’s entirely up to you.
1. Your ecw in Global Mapper. Yellow outline represents my clipping boundary.
The clipped image is ‘SAVED AS’ a new ecw with a new eww (ecw’s world file) then added to Map3D using a Data Connection. Although MAPIINSERT and IMAGEATTACH are mentioned frequently, way too frequently by many forum users, those procedures, despite their popularity should not be considered a ‘best practice’ when inserting images.
A Data Connection gives you the opportunity to verify whether the image’s native projection is being understood. In the event M3D cannot read the projection or reads it incorrectly, the user can override the inaccurate projection. If MAPIINSERT or IMAGEATTACH mistakenly uses the wrong projection (or not use any at all), users are likely to misdiagnose insertion issues and cause them to chase solutions with little or no value.
<<In this exercise modelspace has been assigned Belge72/b.Lambert72A (EPSG 31370). The Data Connect palette in Map3D displayed Unknown for the ecw’s projection—it was unable to read the image’s native coordinate system in the eww file (ecw’s world file) so Unknown projection was replaced with EPSG 31370 (using a manual override).>>
2. Clipped imaged has been added using a Data Connection.
Bing Hybrid map was turned on in modelspace .
3. The ecw with Bing Hybrid as the base map,
Here’s a tighter, zoomed-in view of the roundabout at Rue Jean-Baptiste Moyens & Av. Henri Liebrecht (WGS84 Lat: 50.889982, Long: 4.318037).
4. Bing Hybrid on the left and the ecw on the right.
Based on the zoom-in view in image 4, do you prefer Bing imagery or the ecw?
Chicagolooper
