Dynamic Text Field - Initials
Mikolaj.Biernacki
Mikolaj.Biernacki
First time posting here so please move into appropriate topic if needed.
I'm currently trying to automate filling in some of the details we have to put on our drawings. One of them is a created by text field. I've found option for it to auto-populate with first name initial followed by surname. However, I'd like it to appear as e.g. JS instead of JSmith. Is it possible to do this?
Thanks in advance!
user181
You can use a diesel expression.  Can you show with image or something where you have found the first initial and surname?
ChicagoLooper
Hello @Mikolaj.Biernacki
Assuming you got first name initial followed by surname from the typical ‘login’ user name, then you can use a DIESEL expression.
Example:
User’s 1st name: Smokey
User’s Surname: Bear
Login Name: SBear
The diesel expression would be like this.
Chicagolooper
Mikolaj.Biernacki
I've managed to set this up using a text with a field SystemViariable > username and just changed it from my full name in AutoCAD profile to just initials.
The diesel expression above does work too and is probably a more "correct" solution. Thanks!
