Documentation about "imbatch.exe"?
Peter2_1
Peter2_1
There is the file c:\Program Files\Autodesk\AutoCAD 2018\Map\bin\IMBatch.exe
Documentation in help-File: "No results found"
Search in Forum: No results
Search in AKN: two small hints
Information from EXE-file
on x64 Professional Edition Version 10.0 (build 17763)
File Version Information :
Version language : Deutsch (Schweiz)
Comments : Use Map 3D Batch to run functionality via a batch file, for example a data import or export. Map 3D Batch helps to automate this process.
CompanyName : Autodesk, Inc
FileDescription : Autodesk Map 3D Industry Model Batch
FileVersion : 21.0.100.6
InternalName : IMBatch.exe
LegalCopyright : Copyright 2017 Autodesk, Inc. All rights reserved.
LegalTrademarks : Map 3D
OriginalFilename : IMBatch.exe
ProductName : AutoCAD Map 3D
ProductVersion : 21.0.100.6
Assembly Version : 21.0.100.6
Creation Date : 12/09/2017 09:47:26
Last Modif. Date : 12/09/2017 09:47:26
Last Access Date : 05/02/2019 11:51:24
FileSize : 15816 bytes ( 15.445 KB, 0.015 MB )
FileVersionInfoSize : 2516 bytes
File type : Application (0x1)
Target OS : Win32 (0x4)
File/Product version : 21.0.100.6 / 21.0.100.6
Language : Deutsch (Schweiz) (0x0)
Character Set : 1200 (ANSI - Unicode (BMP of ISO 10646)) (0x4B0)
Build Information :
Debug Version : no
Patched Version : no
Prerelease Version : no
Private Version : no
Special Build : no
imbatch /?
Parameter 'AssemblyName' fehlt
Parameter 'Namespace' fehlt
Parameter 'ClassName' fehlt
Parameter 'Username' fehlt
Parameter 'Password' fehlt
Parameter 'Datasource' fehlt
Parameter 'tbsysUsername' fehlt
Parameter 'tbsysPassword' fehlt
Parameter 'tbsysDataSource' fehlt
Geben Sie diese Parameter in einer Konfigurationsdatei an, oder verwenden Sie Befehlszeilenparameter.
Konfigurationsdatei-Muster:
IMBatch.exe ConfigFile=\\Server\Share\IMBatchFiles\ExportRegionA.xml; OutputFilename=C:\IMExport\ExportRegionA.txt; Username=MY_LAND;
Befehlszeilen-Muster:
IMBatch.exe AssemblyName=myassembly; ClassName=MyClass1; etc.
Weitere Informationen finden Sie in Muster 103 oder in der Dokumentation.
Is there a clear, up-to-date documentation about this program?
AutoCAD Map 3D 2023 German / Oracle
sebastien.baudin
I don't think you'll find documentation about "imbatch.exe". That is used to export data from Map in Interlis format (which is a GIS exchange format in Switzerland). All the necessary files to make imbatch working were in the Topobase structure before it got moved to Map. Now you only find the exe file, because it is still used from customers in Switzerland, but other template files (XML) have been removed from the installation structure of Map.
I hope it helps,
Kind regards,
Sébastien
Sébastien Baudin
Peter2_1
Hi Sebastien
there should be more then Interlis-stuff. One feature is described in AKN (the 1-click-checking), but the string inside the EXE talks also about import / export ,,,,
I'm currently using IMBatch.exe with a custom develop in VB.NET2013 and MAP 2018. You can look in google with "tbbatch.exe" so the old name, but the command had very few changes from 2008 . It's only be renamed
