Announcements
Data table link to cad table
Looking to have autocad  table on plan linked to data table (shape or sdf). Would like to not have to export to csv, format and bring back as table for printing and plan
Mike.M.Carlson
Hi there-
I realize I'm responding to an old post, but I have a possible solution for your consideration.
  1. You would have to import your .shp file via the MAPIMPORT command and create object data.Capture---551f44.JPG
  2. Upon import you will have an Object Data Table created with the .shp attribute fields.
  3. Make sure you're in the Planning and Analysis Workspace and select the Annotate Ribbon
  4. Next you will click on "Define Template"
  5. On the Define Annotation Template dialog click New next to "Template Name" and give it a name
  6. When you click OK, you're brought into a Block Editor interface
  7. Type MAPANNTEXT
  8. The Annotation Text dialog will open (Here's where you will build Tags that correlate with the Object Data Fields)
  9. Type your First Object Data Field Tag name and click the Expression Chooser button on the next field
  10. Expand the Object Data collection and Choose the Object Data Field you want to associate with the new TAG and click OKCapture---551f44-.JPG
  11. Now that you have the TAG named and the associated Expression Chosen, you have to apply some formatting then Click OK
  12. Place the first TAG where you want it near, 0,0
  13. Next you will create some ACAD TEXT Headers in front on of this TAG (This TEXT would be text that describes the TAG)
  14. You repeat this for each Object Data Field you want to show...you may even add some table linework so that it will look like a tableCapture---551f44-WW.JPG
  15. So the RED-colored TEXT are the TAGs with expressions pointing to the Object Data Fields. The Black text and linework are straight ACAD objects/text.
  16. When you have it looking the way you want Close Block Editor and Save the changes to MapAnnTemplate
  17. You are now brought back to the Define Annotation Template Dialog. Now that you have a Template created you can specify the insertion point, linetype, scale, etc.-Click OK
  18. Finally, zoom in on a imported .shp object, and click on Annotate Ribbon again and click Insert and select your Annotation Template and click Insert
  19. select each of your imported .shp objects (in my case I have well locations).
  20. Basically you're associating this Annotation Block to each .shp object and then it pulls in the Object Data field attributes into the Block TAGsCapture---551f44-WWe.JPG
  21. Note how the RED colored fields tie to the Object Data Fields.
  22. If the Object Data changes you can update the annotation as well - this video shows how to do it (check out minute 6:15 of 7:51):
  23. http://civilimmersion.typepad.com/civil_immersion/2017/01/tool-for-tuesday-mapanntext.html
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
