Data Extraction
Data Extraction
Data Extraction
How can I extract the data from the Feature Properties?
Alfred.NESWADBA
open the table-view for your GIS-layer, there you can mark the records and do a simple copy & paste ... or within the same view you find in the bottom line options ==> export.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Pointdump
Alfred,
Export is a nice trick. Very easy and quick!
Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
I tried using EXPORT, and it wasn't working...I don't know if it is because it was an imported data table or what...
BUT
I ended up doing the following:
1) Select the object(s) I need the info for.
2) Right-click and select: Show Data Table
3) Export from the Data Table to an Excel Spreadsheet.
And it got me the info I needed.
Thanks for the help!
Alfred.NESWADBA
Exactly what I suggested, isn't it? 😉
- alfred -
Alfred NESWADBA
