We have ACAD Map 3D and I am still not entirely sure what the purpose of 'Map' is. I would have assumed GIS functionality but that seems limited. I would like to be able to create points that are part of a database, with metadata that I can then export very easily.
Currently if I want to get a point out I must LIST the point(s) I want then copy and paste individual coordinates and then use a different piece of software to capture the metadata.
Surely I should be able to create points easily without so much fuss?
I guess the easiest way to accomplish your 'classic' goal is:
I advise you to press F1 and learn all about the above powerful commands, sir.
two items you can read.
http://www.gisperfect.com/res/AutocadMAP/best_practices.pdf dated 2007 and provides an overview of what map can do. some of the terminology is gone but the theory is current.
http://knowledge.autodesk.com/support/autocad-map-3d/learn-explore#?sort=score this and the tutorials can lead you through the practicals
dave
http://images.autodesk.com/adsk/files/best_practices_for_managing_geospatial_data1.pdf
same baisc document updated to 2010
google autocad map 3d best practices to find other articles
dave
I need to add attributes and I would like it to be easy like in Arc; you can click to add a point and you have the option to enter any attributes you want. You can then label using those attributes and export the data with the XY(Z) coordinates.
I am not fussy what kind of database I use and since I am setting this up as a new process we use I could (within reason) set up anything to store that data. The data does end up in what I think is a Paradox database that Surpac uses but it also saves and .mdb file. Currently I use spreadsheets and then save as .csv for import to the database.
A more direct method might make things faster but the reason we keep it as a .csv is so that people assisting me with data capture won't have access to the dB and so that I can make sure my work is correct before importing the data.
To explain what I am doing in case it helps you help me:
1. I have 2D plans with a borehole drawn on as a line. Values from assay samples are written alongside this line. I need the collar coordinates, azimuth, hole_id and the sample data with their from and to measurements.
2. I capture the collar positions of these using a polyline. I also measure the azimuth of the line using DIST.
3. I need the coordinates of the points on the PL so I use LIST and copy and paste to a spreadsheet. I manually enter the azimuth. I would like points but using LIST I would have to separately copy and paste each coordinate. The lines are very confusing, especially when data is added to this plan and I now hav to figure out what has been captured and what not.
4. I then capture the data into the spreadsheet.
All this is manual and it would be much easier if this could happen automatically directly into the corect format. I would love to be able to also capture the azimuth automatically and not have to type it in.
I would look at creating a schema and features using data connect. The Learn & Explore link posted should provide some help on those, do a seach on each for ideas.
The image you posted looks like a scan/paper image and you are wanting to create a digital file. Do you have any of the coordinates or survey data? Any dwgs to start from? You might even be to export them to a feature file. (SDF would be the easiest to start)
As for the data base I would start with SQLlite, it can contain the geomerty and data.
Have you created a schema with empty geometry and created the properties/attributes? I'll upload a quick video on it, it;s up to you to enter the proper locations.
Take a look
https://screencast.autodesk.com/main/details/c39a10a2-0486-41c5-a580-b5006f9e16a8
