Hi! I want to add new survey points with NEZ data on a blank dwg in the survey data store. Howerer, it registers only NE while Z remains at elevation 0. My drawing coordinates remain also at elevation 0. I can only add a survey point with another elevation than 0 if I write it in the table.
How do I create new survey points by plotting directly on my drawing with elevation of not zero?
Hi, listensson
MAPIMPORT for type txt?
Hi Alexander.
I assume that MAPIMPORT is used if I have a file with points. But I am thinking more of the possibility to create a new point directly in the model view with elevation of not zero.
the directions for that are in map help (F1)
search for
select to work with survey points
and read to create survey points
the xyz will be in the table in the appropriate columns E, N & Elevation
dave
Hi again,
It is available to enter a point only by XY while Z is not available...
try the attached data store
on the survey tab, data & connect to it
click edit
right click the points in the list and select create a new point
enter the x,y,z
that's how I did it. it works. the EN & elevation are to the far right columns of the table.
is this similar to your attempt?
dave
