Creating a Workflow in Acad Map 3d -> Assign Coord System
We're looking into the "Workflow" system in Map3d.
One of our most common tasks is to Set the coordinate system and then add a georeferenced image (such as a SID file).
I'd like to create a workflow that will do this -- but I'm having trouble figuring out how to get it to set the coordinate system. I will eventually need to tell the image what coordinate system to use (we normally have to edit that manually).
I've been searching but keep finding links to the AutoCAD help system which is not very helpful.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Link copied
