Creating a custom linetype using dashed line with text
johnyPZ57P
johnyPZ57P
I have created custom line types with text. These line types have a "continuous" line with the custom text. I need to create a "dashed" line with text, but I can't get the dashed line; I just get a solid line.
This is the desired appearance:   - - - - 864ct UG - - - -
This is the code I generated with /Express tools/tools/ Make Linetype
*864CTUG,864ct Underground Fiber
A,1.249811,-.015002,["864ctUG",Standard,y=-.03,s=.06,u=0],-.383569
but this is what I end up with:
-864ctUG- (the lines are longer than I am showing, see attached PDF Below).
I have tried multiple methods but coming up empty. Any assistance is appreciated.
АлексЮстасу
Try
*864CTUG_---,864ct Underground Fiber
A,0.1812265,-0.1812265,0.1812265,-.015002,["864ctUG",Standard,y=-.03,s=.06,u=0],-.41,0.1812265,-0.1812265,0.1812265,-0.1812265
General principle: positive numbers are lines, negative numbers are spaces.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
johnyPZ57P
Thanks. That will work.
