Create 3D polyline parallel to another.
bjohncarmichael
Message 1 of 10
bjohncarmichael
Good afternoon all,  I have a road layout drawing made up of 3D polylines created from surveyed points.
Is it possible to create a parallel 3D polyline offset by a set amount in X-Y and by a different amount in Z value ?.
Or am I asking for too much !!!
Many thanks in advance, John.
Replies (9)
Message 2 of 10
Pointdump
Hi John,
You can offset and then MOVE 0,0,x.xx.
In Civil 3D you can use Stepped Offset.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 10
bjohncarmichael
Thanks Dave but offset doesn't seem to work in 3D and I forgot to mention that the 3D polylines I want to create parallel are not straight !.
Unfortunately Civil 3D is above my pay scale !!.
Message 4 of 10
Pointdump
John,
What was I thinking? Sorry, of course you're right, offset doesn't work with 3D.
From the end point of your 3D Poly, create a point, offset horizontally and vertically, then copy the 3D Poly snapping end to node. The FROM Command might come in handy.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 10
bjohncarmichael
Thanks Dave, that will work on the straight lines but on curves it needs something more like an 3D version of offset !!
Message 6 of 10
Pointdump
John,
OK, I see. Concentric 3D arcs would be needed. That would be tough.
So is this a roadway centerline that you're wanting to offset to create edges of travelway? Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 10
bjohncarmichael
Hi Dave,
Thanks for your time on this. Unfortunately I cannot post the drawing as it belongs to my client and I believe there may be some copyright issues.
What I am trying to achieve is : we survey the line where the kerb (I believe its called a Curb on your side of the pond ?) meets the highway surface. What I want to do is create a 3D polyline of the top and back of kerb (curb!). So Z+110mm and offset to left of line by 150mm. I have several miles of these to create and I don't think its do-able without a lot of work.
Message 8 of 10
O_Eckmann
You could try with this LISP  (fast written from functions found on web)
Process:
- extract 3D vertex
- convert to 2D vertex
- draw 2D polyline
- offset 2D polyline
- extract 2D vertex
- check same number of 2D vertex after offset as number of vertex of original 3D poly
- update 2D vertex to 3D vertex with X & Y from 2D and Z from 3D + vertical offset
- make 3D poly from 3D vertex
No test for offset value, or result of offset. Should work in most case but not every.
Olivier
Olivier Eckmann
Message 9 of 10
bjohncarmichael
Thank you very much Oliver, that works brilliantly, you are a genius !.
Thanks again.  John.
Message 10 of 10
bjohncarmichael
Can I just add, that in my line of work the Lisp you provided me with is one of the most useful time saving tools I have come across (I am easy to please !).
Thank you once again.
