AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Copy with base point also copies all other objects on the same layer
9 REPLIES 9
Message 1 of 10
s.proch
395 Views, 9 Replies
Hello all!
So I have some pipes in a model that I need to copy to a different drawing. Now, it doesn't matter which selection method I use (window, crossing, or click one by one), copy with a base point also copies all pipes on the same layer and in the same network. It even prompts me when I do CTRS+SHIFT+C that there are 6 objects selected, but all 10000+ pipes copy too. Any thoughts?
Labels (3)
9 REPLIES 9
Message 2 of 10
imadHabash
in reply to: s.proch
If you completely close your AutoCAD then open it again, any changes?
Message 3 of 10
Kent1Cooper
Are they GROUPed together?
Kent Cooper, AIA
Message 4 of 10
s.proch
in reply to: imadHabash
Nope, that didn't help. Also, it doesn't matter whether I use 2022 or 2023. And it doesn't matter if I copy stuff between drawings or within a single one.
Message 5 of 10
s.proch
in reply to: Kent1Cooper
No, they aren't grouped.
Message 6 of 10
imadHabash
Can you share a part or all of your CAD dwg file for testing?
Message 7 of 10
s.proch
Here is a small copy. Also, attached is the event viewer that I get upon pasting the items to a different model.
Message 8 of 10
cadffm
Look at the Program titelbar, this is not AutoCAD,
look at the door sign, this is not CIVIL3D
= wrong board, it's a Civil thing.
https://forums.autodesk.com/t5/civil-3d/ct-p/4003
Sebastian
Message 9 of 10
pendean
Your AutoCADMAP3D AECPipes content always act as one in AutoCADMAP3D, which is not the topic of this forum.
Let's get your post moved to the MAP3D forum so your software peers can offer more guidance.
Message 10 of 10
s.proch
Sorry for the confusion, this is all actually created in Civil3D
Technology Administrators
