Hi all,
I need to export data from an Oracle-connection (application module). Regardless of the definition of the application module, what is the best way (best practice) to export points, lines and polygons in a WYSIWYG-way?!
In my special case I'm dealing with lines and their appearance.
So, short story long ![]()
<SymbolInstance>
<SimpleSymbolDefinition>
<Name>LTYP8</Name>
<Description>GEOBOX Abwasser, Haltung, Axe, ungenau</Description>
<Graphics>
<Path>
<Geometry>M 0,0 L 900,0</Geometry>
<ScaleX>%SCALEX%</ScaleX>
<ScaleY>%SCALEY%</ScaleY>
<LineColor>%LINECOLOR%</LineColor>
<LineWeight>%LINEWEIGHT%</LineWeight>
<LineWeightScalable>false</LineWeightScalable>
<LineCap>%LINECAP%</LineCap>
<LineJoin>%LINEJOIN%</LineJoin>
</Path>
</Graphics>
<LineUsage>
<Repeat>1200</Repeat>
</LineUsage>
<ParameterDefinition>
<Parameter>
<Identifier>LINECOLOR</Identifier>
<DefaultValue>0xff000000</DefaultValue>
<DisplayName>Linienfarbe</DisplayName>
<Description>Linienfarbe</Description>
<DataType>LineColor</DataType>
</Parameter>
<Parameter>
<Identifier>LINEWEIGHT</Identifier>
<DefaultValue>0.0</DefaultValue>
<DisplayName>Linienstärke</DisplayName>
<Description>Linienstärke</Description>
<DataType>LineWeight</DataType>
</Parameter>
<Parameter>
<Identifier>SCALEX</Identifier>
<DefaultValue>1.0</DefaultValue>
<DisplayName>Pfad Skalierfaktor X</DisplayName>
<Description>Pfad Skalierfaktor X</Description>
<DataType>Real</DataType>
</Parameter>
<Parameter>
<Identifier>SCALEY</Identifier>
<DisplayName>Pfad Skalierfaktor Y</DisplayName>
<Description>Pfad Skalierfaktor Y</Description>
</Parameter>
<Parameter>
<Identifier>LINECAP</Identifier>
<DefaultValue>'Round'</DefaultValue>
<DisplayName>Linienabschluss</DisplayName>
<Description>Linienabschluss</Description>
</Parameter>
<Parameter>
<Identifier>LINEJOIN</Identifier>
<DisplayName>Linienverbindung</DisplayName>
<Description>Linienverbindung</Description>
</Parameter>
</ParameterDefinition>
</SimpleSymbolDefinition>
<ParameterOverrides>
<Override>
<SymbolName>LTYP8</SymbolName>
<ParameterIdentifier>LINECOLOR</ParameterIdentifier>
<ParameterValue>Lookup (ID_UTILISATION,0xFFFFFF00,1,0xFF000000,2,0xFF0000FF,3,0XFF00FF00,4,0XFFFF0000,5,0xFFFF00FF,6,0xFF0000FF,7,0xFF0000FF,8,0XFFFF0000,9,0xFF000000,10,0xFF0000FF)</ParameterValue>
</Override>
<Override>
<ParameterIdentifier>LINEWEIGHT</ParameterIdentifier>
<ParameterValue>250</ParameterValue>
</Override>
<Override>
<ParameterIdentifier>SCALEX</ParameterIdentifier>
<ParameterValue>1</ParameterValue>
</Override>
<Override>
<ParameterIdentifier>SCALEY</ParameterIdentifier>
</Override>
<Override>
<ParameterIdentifier>LINECAP</ParameterIdentifier>
<ParameterValue>'None'</ParameterValue>
</Override>
<Override>
<ParameterIdentifier>LINEJOIN</ParameterIdentifier>
<ParameterValue>'Round'</ParameterValue>
</Override>
</ParameterOverrides>
<ScaleX>1</ScaleX>
<ScaleY>1</ScaleY>
<SizeContext>MappingUnits</SizeContext>
<UsageContext>Line</UsageContext>
<GeometryContext>LineString</GeometryContext>
</SymbolInstance><SymbolInstance>
<Name>LTYP8</Name>
<Graphics>
<Path>
<Geometry>M 0,0 L 9,0</Geometry>
</Path>
</Graphics>
<LineUsage>
<Repeat>12</Repeat>
</LineUsage>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Override>
</Override>
<Override>
</Override>
<Override>
</Override>
<Override>
</Override>
<Override>
</Override>
<Override>
</Override>
<ScaleX>100</ScaleX>
<ScaleY>100</ScaleY>
</SymbolInstance>
What I want:
I tried to modify the properties of the polyline in the DWG. Finally I came to this:
In a PDF-plot it looks like (only one purple line is modified):
Why I need to set the line type factor (Linientypfaktor) to 30 is not quite clear to me. But the parameter "global width" (Globale Breite) seems to be a hint.
The aiming scale has always been 1:100.
How can I control this?
Any hints or solutions are appreciated!
Cheers,
Maria
Hi Maria,
when you export to DWG - which option do you use with "MAPTOACADUSELINEWEIGHT"?
Befehl: MAPTOACADUSELINEWEIGHT Methode zum Konvertieren der Linienstilstärke auswählen [Linienstärke/Polylinienbreite] <Linienstärke>:p
Rob
Hi Robert!
I didn't know of this parameter. Thanks, that helped a bit.
Now the DWG looks like
But how can I set the Line Type Factor (Linientypfaktor)?
Hi Maria,
we solved this by configuring our Map layers in a specific way. There might be other possibilities.
DWG Export has changed - with Map 2013 we had to workaround certain issues wich have been fixed in newer releases.
You will find more about how we set up our layers on this blog:
https://raumpatrouille3d.blogspot.ch/search?q=linien
The older posts are in German, the newer ones in English.
Rob
Hey Rob,
alright, I am now getting closer. MAPTOACADUSELINEWEIGHT and layer-definitions have to play together. I need to overhaul the files...
One more question which arose in the meantime: Is it possible to export offset lines? The path-definition looks like: M 0,5 h 4.0, thus an offset in direction of Y. My DWG is straight on Y=0. That's it?
Hi Maria,
with regards to the offset - I dont know. We never had the situation as far as I remember.
I'm not sure - I think an AutoCAD line needs to start with a line. You would need to have a look on the AutoCAD side as there is propably not option/setting in Map export/layer configuration for that.
Rob
