EATTEDIT, I use this all the time in our title blocks. Here's what autocads
help file says.
- R. Brockman
Edits attributes in a block reference
Modify II toolbar:
Modify menu: Object Attribute Single
Command line: eattedit
Select a block:
You are prompted to select a block in the drawing area. After you select a
block with attributes, the Enhanced Attribute Editor is displayed.
If the block you select does not contain attributes, or you select something
that is not a block, an error message is displayed, and you are prompted to
select another block.
"OIVIND" <nospam@address.withheld> wrote in message
news:23443290.1073554160104.JavaMail.jive@jiveforum1.autodesk.com...
> halloo. I want to change the height of the text (the name of the block) in
a block with attributes. I have tried to use battman, refedit, and some
others.
> I have about 300 blocks that I want to change and i cant redefine the
blocks so that the whole drawing is updated.
> I really don't want to click on each one of themto change them one by one!
> Can anybody help me?
Attachment not added (too many attachments): "ac.cmdaccess_blank.gif"
Attachment not added (too many attachments): "ac.menuaro.gif"
Attachment not added (too many attachments): "ac.keyboard.gif"
