Cannot resize columns in data table palette.
toolbox2
toolbox2
Just moved to AutoCAD Map 2019. I cannot resize the columns in the data table palette. The columns widths automatically vary with the cell content but cannot be manually changed. Right-clicking on the column heading gives no option except "Create calculation".
I can re-order columns and change the row widths. Just not the column width.
Is this normal behaviour? At least in v2016 I could resize columns - the frustration then was that M3D would not retain the widths.
Using AutoCAD Map 2019 (patched with the 2019.0.1 Update and AutoCAD 2019.1.2 Update)
Peter2_1
Confirmed for 2018, German.
(Only the first column "Benachrichtigungstyp" can be modified.)
AutoCAD Map 3D 2023 German / Oracle
