Hello. I have been looking for the map 3D tool set in autocad and also on the site and can't really find how to get it.
On the site it says "The 2022 Map 3D tool set is included with AutoCAD" which means that it should be included in my
Solved by DarrenP. Go to Solution.
its explained here: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Only-One...
You will be able to access AutoCAD including specialized toolsets from Autodesk Accounts and the Autodesk desktop app.
DarrenP
DarrenP
Thank you. Maybe I was not looking well but found it hard to find this information.
