Autocad Map 3D Toolbars flickers
schikh
Message 1 of 10
schikh
We are having the anoyng problem with Autocad Map opened in fullscreen, when we zoom or move the map the toolbars flickers. When Autocad is not in full screen the flickers disapear, but reaper when we move the window  to the  right of the screen over an area about 32 pixels wide !
The attached video  shows what is going on.
Can someone have a look into that ?
Saïd Chikh
  • Ores
Replies (9)
Message 2 of 10
Pointdump
Hi Saïd,
Welcome to the Autodesk Forums.
Maybe use GRAPHICSCONFIG to turn off Hardware Acceleration.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 10
schikh
Hi Dave,
I have just tried GRAPHICSCONFIG On and Off but doesn't change anything 😞
Thanks anyway
Message 4 of 10
ChicagoLooper
Try this:
Right-click an icon on one of the Toolbars==>Lock Location==>Select Docked Toolbars/Panels.
Chicagolooper
Message 5 of 10
schikh
Thanks but doen't seem to work either.
Message 6 of 10
schikh
Thanks but doesn't seem to work either
Message 7 of 10
ChicagoLooper
As an experiment, arrange your Toolbars vertically instead of horizontally. Either place them on the left or right edge of your monitor. Make sure the Toolbars are arranged side-by-side with only one Toolbar per 'vertical column.'
You already know flickering occurs when the Toolbars are horizontal. In this experiment, does the flickering persist when the Toolbars are vertical?
Chicagolooper
Message 8 of 10
schikh
Unfortunatly same problem when the toolbars are vertical and placed on the left or right.
Thanks anyway.
Message 9 of 10
pendean
Community Legend
Community Legend
2020 is not new: so what is with your setup?
Is this a laptop with a second monitor?
Post a screenshot of your ABOUT and GRAPHICSCONFIG command pop-ups please.
And if I may ask, why all those toolbars PLUS the Ribbon? Do you not enjoy a larger drafting area? Or just don't know you can turn off the RIBBON or at least minimize it to just a toolbar? These latter options may help as well.
Message 10 of 10
schikh
From Autodesk support the problem is the graphics card is not certified, only some NVIDIA or AMD/RADEON cards certified, all Intel are not.
