Autocad Map 3D & Google Earth
Hello, everyone,
I would like to see some points (geo-referenced data) on Google Earth, is appropiate Autocad Map 3D?
I would like to calculate the distances between them (on Google Earth), is it possible?
Thank you soo much.
Antonio
braudpat
Hello
Welcome to the Autodesk / AutoCAD Forums !
1) ACAD MAP can't "see" Google Earth Infos ...
2) You must add a Non-Free Plugin to be able to see Google Earth Infos into ACAD / ACAD MAP / etc !
For example: http://www.plexearth.com/
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
parkr4st
download and install GE pro.  It is free.
under the file menu;  import   you can import a variety of file types including .csv and .shp
Map3d can produce the shp
dave
