Thank you for the fast response.
We are running AutoCAD Map 3D 2013
I will post screen shots at the bottom of this post.
Unfortunately, there are not servicepacks available for Map 3D 2013.
Yes, we use FDO-connections. SHP Connections.
Just ran Windows Memory Diagnostic. No errors.
Memory is running at the same speed.
I just put in a new set of RAM, same manufacturer, model. Same issues still exist.
I formatted the Hard Drive. Reinstalled Windows 7 64bit. Before I did anything else, loaded AutoCAD Map 3D 2013 Right away. Same issues exist.
When you open the drawings,
You can see in the bottom left the progress bar loading to 100% many times untill it the memory get to around 4 Gb and then AutoCAD Map 3D 2013 Freezes (Crashes). I've tried mutilable maps where it loads alot of data and I have the same issues. I can load smaller maps no problem.
Log Name: Application
Source: Application Error
Date: 7/3/2012 12:25:03 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Description:
Faulting application name: acad.exe, version: 25.0.55.0, time stamp: 0x4f309abd
Faulting module name: MSVCR100.dll, version: 10.0.40219.1, time stamp: 0x4d5f034a
Exception code: 0xc00000fd
Fault offset: 0x0000000000057fa9
Faulting process id: 0xa6c
Faulting application start time: 0x01cd593812709720
Faulting application path: C:\Program Files\Autodesk\AutoCAD Map 3D 2013\acad.exe
Faulting module path: C:\Windows\system32\MSVCR100.dll
Report Id: a4476c52-c52b-11e1-8644-cc52af4403a0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-07-03T16:25:03.000000000Z" />
<EventRecordID>1176</EventRecordID>
<Channel>Application</Channel>
<Computer>amarvin-WIN764.dutil.com</Computer>
<Security />
</System>
<EventData>
<Data>acad.exe</Data>
<Data>25.0.55.0</Data>
<Data>4f309abd</Data>
<Data>MSVCR100.dll</Data>
<Data>10.0.40219.1</Data>
<Data>4d5f034a</Data>
<Data>c00000fd</Data>
<Data>0000000000057fa9</Data>
<Data>a6c</Data>
<Data>01cd593812709720</Data>
<Data>C:\Program Files\Autodesk\AutoCAD Map 3D 2013\acad.exe</Data>
<Data>C:\Windows\system32\MSVCR100.dll</Data>
<Data>a4476c52-c52b-11e1-8644-cc52af4403a0</Data>
</EventData>
</Event>
Date: 7/3/2012 11:57:47 AM
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: amarvin-WIN764.dutil.com
Description:
Faulting module name: StyleConversion.dll, version: 2.4.0.5642, time stamp: 0x4f39c787
Fault offset: 0x0000000000164537
Faulting process id: 0xab0
Faulting application start time: 0x01cd5933f4894de6
Faulting module path: C:\Program Files\Autodesk\AutoCAD Map 3D 2013\StyleConversion.dll
Report Id: d52f6193-c527-11e1-8644-cc52af4403a0
Event Xml:
<System>
<Level>2</Level>
<Task>100</Task>
<TimeCreated SystemTime="2012-07-03T15:57:47.000000000Z" />
<EventRecordID>1168</EventRecordID>
<Security />
</System>
<EventData>
<Data>StyleConversion.dll</Data>
<Data>2.4.0.5642</Data>
<Data>4f39c787</Data>
<Data>0000000000164537</Data>
<Data>ab0</Data>
<Data>01cd5933f4894de6</Data>
<Data>C:\Program Files\Autodesk\AutoCAD Map 3D 2013\StyleConversion.dll</Data>
<Data>d52f6193-c527-11e1-8644-cc52af4403a0</Data>
</EventData>
</Event>
<?xml version="1.0" encoding="UTF-16"?>
<WERReportMetadata>
<OSVersionInformation>
<WindowsNTVersion>6.1</WindowsNTVersion>
<Build>7601 Service Pack 1</Build>
<Product>(0x1): Windows 7 Ultimate</Product>
<Edition>Ultimate</Edition>
<BuildString>7601.17835.amd64fre.win7sp1_gdr.120503-2030</BuildString>
<Revision>1130</Revision>
<Flavor>Multiprocessor Free</Flavor>
<Architecture>X64</Architecture>
<LCID>1033</LCID>
</OSVersionInformation>
<ParentProcessInformation>
<ParentProcessId>744</ParentProcessId>
<ParentProcessPath>C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe</ParentProcessPath>
<ParentProcessCmdLine>"C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe" /O "C:\Users\amarvin.POWER\Desktop\WATER.dwg"</ParentProcessCmdLine>
</ParentProcessInformation>
<ProblemSignatures>
<EventType>APPCRASH</EventType>
<Parameter0>acad.exe</Parameter0>
<Parameter1>25.0.55.0</Parameter1>
<Parameter2>4f309abd</Parameter2>
<Parameter3>MSVCR100.dll</Parameter3>
<Parameter4>10.0.40219.1</Parameter4>
<Parameter5>4d5f034a</Parameter5>
<Parameter6>c00000fd</Parameter6>
<Parameter7>0000000000057fa9</Parameter7>
</ProblemSignatures>
<DynamicSignatures>
<Parameter1>6.1.7601.2.1.0.256.1</Parameter1>
<Parameter2>1033</Parameter2>
<Parameter22>4ba2</Parameter22>
<Parameter23>4ba2cbfd608e22394128ef38fa7c0871</Parameter23>
<Parameter24>3cc6</Parameter24>
<Parameter25>3cc6ff6187e2f4d20fc296f4ab4daaaf</Parameter25>
</DynamicSignatures>
<SystemInformation>
<MID>C0CC4CDD-297E-4F18-BF1F-456A3A0C0211</MID>
<SystemManufacturer>LENOVO</SystemManufacturer>
<SystemProductName>7052C9U</SystemProductName>
<BIOSVersion>9HKT51AUS</BIOSVersion>
</SystemInformation>
</WERReportMetadata>
