Autocad Map 3d 2023 installation/ uninstall
Hi everyone,
Anyone out there have any luck installing Autocad map 3d 2023 with intune? autodesk itself doesnt support it and they changed the creation of a deployment. it seems it will only install to the path that is set during the creation of a deployment package ( in our case as a test c:\install) i tried changing those paths to .\ or .\image (depending on the action\location), but it seems to only work when its hardcoded to c:\install\... i was thinking of using a powershell script to copy the deployment files to c:\install and run it like that and cleanup the install files. but trying to figure out an easier approach https://xender.vip/ https://omegle.onl/.
this also brings me to the uninstallation. in the .bat file its made a command for silent, basic gui and uninstall. the problem is the uninstall refers to the the install files which (using my idea with powershell) wouldnt exist anymore. i found a different approach that seems to work but thats not uninstalling all components.
i could use a different app for installation and uninstalling, but that doesnt seem like the right approach to me. any one able to point me in the right direction or that has had succesfully been able to install and uninstall?
forgot to mention: this is on Azure ad only devices so cant use a UNC path for installation.
