We can get this info from dmp file, seems more like connection time out. But, with the same tool we are able to connect oracle DB(through Data Connections by Provider) and export dwg diagram to spatial schema.
Not sure why this issue is coming with only dbconnect.
ROOT CAUSE:
coldfusion.runtime.RequestTimedOutException: The request has exceeded the allowable time limit Tag: cfoutput
at coldfusion.tagext.io.OutputTag.doAfterBody(OutputTag.java:208)
at cfDA22ecfm656655218.runPage(E:\inetpub\wwwroot\Portal\dump\DA2.cfm:315)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:126)
at coldfusion.CfmServlet.service(CfmServlet.java:175)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable
