AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD 2015 Blocks Gallery
2 REPLIES 2
692 Views, 2 Replies
I am new to AutoCAD Map 3D 2015 version.  I have read about the new features to acad 2015 and wondering if Map 3D has the option as well to show the block gallery when using the insert button.  I do not see a 'down' arrow below the insert button in the ribbon so I am wondering if there is a setting that needs to be turned on or if it isn't available in this version.  I would love to use it since I just started a new job and aren't familar with all the blocks.  The preview of them would be extremely helpful. The image below is what I have:
2 REPLIES 2
Alfred.NESWADBA
you are correct, the AutoCAD 2015 feature is not ported to the AutoCAD Map 3D menu.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Murph_Map
You can use the Design Center (type DC at the command line) then browse to any dwg and see the blocks in those dwgs. If you find one you need drag/drop will let you insert it into your drawing/map.
Murph
Supporting the troops daily.
