ATTSYNC NOT WORKING
ATTSYNC NOT WORKING
johnyPZ57P
ATTSYNC NOT WORKING
johnyPZ57P
I have a block with attributes set to INVISIBLE (yes). In the past, I could open that block in the block editor, select the attributes, change INVISIBLE to (no), and save the block. At the command prompt, type ATTSYNC and select the block; the attributes for that block would now be visible. It is not working today. I have REGENALL and closed and opened the drawing. Any suggestions?
AutoCAD Map 3D 2025, Update 2025.0.1.
johnyPZ57P
Never mind, it started working. Not sure what I did to make it work. I started to print the drawings and they appeared. Not sure how to cancel this post.
ChicagoLooper
@johnyPZ57P
You don't need to go to BLOCK EDITOR.
Use the BATTMAN command.  Or go to Insert Tab=>AutoCAD Attributes Panel=>Manage Icon.
Chicagolooper
johnyPZ57P
Great. I like it. Thanks.
