Associative Map Annotation Template with multiple Attributes
I've successfully created a Map Annotation Template with a single attribute and linked it to an object data field and assigned an associative text style to the attribute. Using Block Editor I make the block associative and then edit the block and make the attribute associative and assign an associative scale to the attribute. When I insert the block it responds to changes in the current associative scale and displays properly.
Life's good so far, however, I need to define other associative Map Annotation Templates that have two or more attributes. When I do, the text scales properly, but the insertion points for the attributes fail to update and I end up with overwritten text. Does anybody know of a way to get the insertion points for the attributes to update relative to the block definition when I change the CANNOSCALE value?
Thank you,
Land Surveyor
Bureau of Land Management
California State Office
