ArcGIS Connection
ArcGIS Connection
JeremyNeufeld7186
ArcGIS Connection
JeremyNeufeld7186
Using Map 3D 2019 I'm trying to connect to an ArcSDE Enterprise connection.  The database is stored in SQL Server with no instance name.  When I connect using the server name in both the server name and instance name fields I get the following error: "ESRI: Entry for SDE instance not found in services file."  I'm not sure how to go about getting this connection established.  I'd appreciate any help available.
Thanks.
JeremyNeufeld7186
I was able to get a little bit further.  If I use the Add ArcGIS Connection and select ArcSDE Enterprise I can connect with the following:
Server name: <sqlservername>
Instance Name: sde:sqlserver:<sqlservername>
Data store: <database name>
I'm connecting using sa for permissions while testing.  The problem with this is that the data comes in read only.  I'm unable to modify it in Map 3D
When I attempt to use the Add ArcSDE Connection using the same server name, instance name and credentials I get the following error:
Failed to connect.
FDO Provider entry point function 'CreateConnection' returned NULL.
Gary_Braun
SA is the SQL db Admin but may not be a geodatabase user, I would try the ArcGIS Connection with a different user. You must have a named geodatabase user having read-write access that you can use to test the connection.
Also, after adding data to your map you may need to use the MAPEDITSETAUTO command to toggle editing. I have to in any case.
JeremyNeufeld7186
The MAPEDITSETAUTO command did it.  Thank you very much!
