Anything using ADE_OD on Visual Lisp freezes the Autocad Model Space
I'm trying to use OD table on Visual Lisp Autocad Map 3D 2019 but it always freezes no matter what "ade_od" function I use. Should I load something before ade_od commands?
Here is one example:
; Define new table (from Object Data Functions Manual)
(setq tabldefn
'(("tablename" . "NEWTABLE")
("tabledesc" . "New Sample Table")
("columns"
; Define a field
(("colname" . "FIELD1")
("coldesc" . "Field1 Description")
("coltype" . "character")
("defaultval" . "Default Value"))
; Define more fields as needed
; Create the new table
(ade_oddefinetab tabldefn)
Thanks in advance
Maybe I found a solution...
For anyone interested check attached file test1.lsp (did not freezes Autocad Model Space)
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/map-query-through-lisp/td-p/2235108
(setq ade_cmddia_before_qry (getvar "cmddia"))
(setvar "cmddia" 0)
(mapcar 'ade_dwgdeactivate (ade_dslist))
After using any ADE_OD commands run
(setvar "cmddia" ade_cmddia_before_qry)
АлексЮстасу
Hi, Luis,
Programming questions about are probably best answered by Autodesk Developer's Network (ADN).
You've probably seen themes about add-ons for OD (ODEDIT, ODCLASS)? But You need to add something else to work with OD that isn't there?
(I've noticed that in ODEDIT, many use only 3-4 commands out of 35!)
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Thanks for the tips!
The solution is indeed the use of
as I have mention before
Regards.
АлексЮстасу
What tasks do you want to solve with your Lisp?
(I think that, perhaps, we in ODEDIT, ODCLASS made a lot of unnecessary commands. But the necessary actions are not done...)
I'm using ADE_OD to add attributes to polylines and later this attributes will be exported using mapexport, Feature Class and Select Attributes to be used on Infraworks.
That's  not an issue anymore, it was solved.
Now, I am struggling to integrate Sqlite database wih Autolisp.
Thanks again!
