ALT TAB not functioning normaly
mrbeegee
Message 1 of 15
mrbeegee
When i have multiple! drawings open in MAP 3D, ALT TAB does't work normal anymore.
When i want to switch between autocad and Excel, I can switch from excel to Autocad with one ALT TAB. When switching back from Autocad to excel one ALT TAB keeps my in Autocad and it requires ALT 2x TAB to switch back to excel. How do i fix that?
Replies (14)
Message 2 of 15
Barzdil
Hello, are You always working with multiple opened drawing in CAD?
Message 3 of 15
mrbeegee
No, but mostly i do have more drawings open.
With only one drawing open the function ALT TAB works fine.
Message 4 of 15
Barzdil
In my civil 2016 helps comman "TASKBAR" and enter valu "0". Maybe it will hep You
Message 5 of 15
mrbeegee
It helps for my too!
The Autodesk icon in the taskbar shows now only 1 drawingpicture in stead of my 2 open drawings when hovering over it, but that' s no problem for me.
It is a bug that Autodesk needs to fix.
Message 6 of 15
Barzdil
Yes, I know that it shows only one tab..  So You may find it convenient to walk through the CAD drawings with "CTRL+TAB"  🙂
Message 7 of 15
Works in AutoCad 2018 too, thanks ;D
Message 8 of 15
Thank you, it works in Autocad LT 2021 as well.
Message 9 of 15
muneer3dsmax
Community Visitor
Community Visitor
Works in Autocad 2021 too!
Message 10 of 15
bumglue
Brilliant, thanks. This also works for AutoCAD LT 2022.
Message 11 of 15
jcarithers
Just chiming in... this worked for me. TASKBAR variable was "1". Switched it to "0".  Not sure how it ever got messed up in the first place. Been driving me just crazy enough not to go look for a solution amidst everything else.
Message 12 of 15
idigg-be
the "solution" is not to set "taskbar to 0".  the ISSUE is that you cant "set taskbar to 1" without breaking your alt+tab functionality.  it is absurd that after all these years, this is still broken.  I need to be able to see numerous drawings in alt+tab and the windows taskbar, but i cannot because it breaks alt+tab.
Message 13 of 15
pendean
Community Legend
Community Legend
@idigg-be wrote:
...I need to be able to see numerous drawings in alt+tab and the windows taskbar, but i cannot because it breaks alt+tab.
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
And/or ask Autodesk for a future program change here, do it often and encourage a few thousand others to do the same
https://www.autodesk.com/company/contact-us/product-feedback
Message 14 of 15
idigg-be
the concept of having to waste my time to beg autodesk to fix a very obviously broken feature is absurd.  a $2800/year program should have issues fixed promptly.
Message 15 of 15
pendean
Community Legend
Community Legend
@idigg-be wrote:...the concept of having to waste my time to beg autodesk to fix a very obviously broken feature is absurd.  a $2800/year program should have issues fixed promptly.
you do you, but reality is they can't fix what no one complains to them directly and constantly to them 100% of the time: Autodesk is giant corporation with 1000s of interested, looking around here for "what to fix" ain't one of them, never has been in decades, still is not. And they sure as heck don't go back to fix anything all of us just never suffer from 100% of the time that stops us all from paying.
Enjoy your soapbox stance!
