I notice that there is an issue with the following metric files:
The tiles seems ok but the related layout is shift (see attached figures). I try to fix them by “Identify template placeholder” but I do not succeed.
The imperial template Map Book Template 11x17 Classic.dwt is OK
Many thanks for any clarifications on this issue.
Ennine,
I don't understand the problem. Can you elaborate a little?
Dave
Dave Stoll
Las Vegas, Nevada
Dear Dave,
I apologize to reply very late.
Kindly find attached a quick video showing an example with Map Book Template ISO A0 classic.dwt (metric).
We notice that the “zoom tile” is offset from the “zoom layout”.
Many thanks in advance for any helps.
Best regards
I am having the same problem with the 11x17 Imperial template in 2017. Is there a fix for the tile shift?
Hi Dixon,
I notice that Map Book with imperial templates are correct (note that I use autocad Map 2017 french version), but the issue is with metric templates.
I join a video to illustrate the aforesaid.
Regards
Hi all,
is there a solution for this?
I have some DWT files that show this shift - others do not. I tried to change my DWT with SCALE to make it work but I was not sucessfull.
Do you have an idea?
Best regards,
Paul
Hi Paul,
It appears that this is an issue with the type of file templates. I hope that the specialists of this forum would consider this issue soon.
Regards
