which references required for connect objectdata (map 2019)
jan_tappenbeck
jan_tappenbeck
hi!
i want to read objectdata and found example code by https://forums.autodesk.com/t5/autocad-map-3d-developer/problem-accessing-objectdata/td-p/2911552
but my problem is which reference are required to call "Autodesk.Gis.Map.ObjectData.Tables" (this is marked in following code:
 Dim tables As Autodesk.Gis.Map.ObjectData.Tables = Autodesk.Gis.Map.HostMapApplicationServices.Application.ActiveProject.ODTables
            Using records As Autodesk.Gis.Map.ObjectData.Records = tables.GetObjectRecords(0, entity.Id, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead, False
could someone help?
regards Jan
fieldguy
"ManagedMapApi" is the reference and for me the path is
C:\Program Files\Autodesk\AutoCAD 2018\Map\ManagedMapApi.dll
You might also need OSGeo - depending on what your doing.
C:\Program Files\Autodesk\AutoCAD 2018\Map\bin\GisPlatform contains
OSGeo.MapGuide.Foundation.dll
OSGeo.MapGuide.Geometry.dll
OSGeo.MapGuide.PlatformBase.dll
remember "Copy local" should be false.
jan_tappenbeck
Moin!
i added references
and define imports:
Imports System
'Imports Microsoft.VisualBasic
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports ManagedMapApi
Imports OSGeo.MapGuide.Foundation
Imports OSGeo.MapGuide.PlatformBase
and here the names of Imports are marked with no correction-options!
Addition:
i have a new idea and reduce import to
'Imports ManagedMapApi
then the marked commands of starting this post are not marked!
i hope it will works
regards Jan
norman.yuan
There is no namespace called "ManagedMapApi". Instead, the namespace in the ManagedMapApi.dll is like "Autodesk.Gis.Map...", that is, for dealing with ObjectData in AutoCAD Map, you probably need these "Imports..."
Imports Autodesk.Gis.Map
Imports Autodesk.Gis.Map.Project
Imports Autodesk.Gis.Map.ObjectData
Imports Autodesk.Gis.Map.Constants
As @fieldguy suggested, you may need those "OSGeo.xxx.xxx" depending on what you do with AutoCAD Map. If you only deal with ObjectData, not FDO data source, then there is no need to add references to those DLLs, which is harmless, but unnecessary dependencies to your project.
Norman Yuan
Drive CAD With Code
